Having trouble building firmware - tup error
When i run make, i get the following error:
tup error: Unspecified output files - A command is writing to files that you didn’t specify in the Tupfile. You should add them so tup knows what to expect.
– Delete: %SystemDrive%\ProgramData\Microsoft\Windows\Caches\cversions.2.db
*** Command failed due to errors processing the output dependencies.
my Tupfile.ini is blank and I also tried changing the file extension of cversions.2.db to cversions.2.db111 and I still got the same error.
Any ideas on how to solve this?
Delete your build folder and the .tup folder, then try again?
Hi, How did you solve this problem?
I tried to compare the successfully compiled(maybe ^ ^) autogen file and previous one. That’s no difference!!
I also get cversions.2.db, but I am not familiar with lua language.
Thanks,
MS
