I believe this question is for customer support. I am a motor newbie so I may be missing something obvious. I recently purchased both a D5065 motor and AMT212 encoder from ODrive. I assumed that no other parts were needed. Based on the video/PDF instructions from " AMT Mounting Instructions | CUI Devices". It shows the encoder directly mounted the motor (for the motor they show), but this does not possible with the D5065 motor. The holes don’t align… Do I need a different encoder base plate to make this work??
thanks
16384 CPR Absolute RS485 Encoder with Cable for ODrive Pro or S1]
|CUI-AMT212B-V-OD-S1-2m|
[Dual Shaft Motor - D5065 270kv]
