I am tired figuring out my Electric motor BLDC motors. Now started with a Hoover motor, take out from a Hoover-X but still getting errors following the setup guide provided at Odrive. @towen Do I need to add an extra 22nf or 44nf Capasitors in M0 & M1?
In [17]: odrv0.axis0.encoder
Out[17]:
config:
abs_spi_cs_gpio_pin: 1 (uint16)
bandwidth: 100.0 (float)
calib_scan_distance: 150.0 (float)
cpr: 90 (int32)
direction: -1 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: False (bool)
index_offset: 0.0 (float)
mode: 1 (uint16)
phase_offset: 0 (int32)
phase_offset_float: 0.0 (float)
pre_calibrated: False (bool)
use_index: False (bool)
use_index_offset: True (bool)
count_in_cpr: 0 (int32)
delta_pos_cpr_counts: 0.0 (float)
error: 16 (uint16)
hall_state: 4 (uint8)
index_found: False (bool)
interpolation: 0.5 (float)
is_ready: False (bool)
phase: 0.0 (float)
pos_abs: 0 (int32)
pos_circular: 0.0 (float)
pos_estimate: 0.0 (float)
pos_estimate_counts: 0.0 (float)
shadow_count: 0 (int32)
spi_error_rate: 0.0 (float)
vel_estimate: 0.0 (float)
vel_estimate_counts: 0.0 (float)
In [18]: dump_errors(odrv0, True)
system: no error
axis: no error
motor: no error
encoder: Error(s):
ENCODER_ERROR_ILLEGAL_HALL_STATE
axis1
axis: no error
motor: no error
