Hello Howard, I don’t think you are doing anything really wrong, and that’s probably why the previous post was unanswered. if ODrive stops taking commands after you enter CLOSED_LOOP_CONTROL, you may have motor switching noise affecting the USB connection.
Can you check system log for USB error messages when you get ChannelBrokenException?
Also do you have an USB-UART converter or an arduino to check if you can issue CLOSED_LOOP_CONTROL and control the motor using physical uart interface?
Hi naktamello, Thank you very much for the response, information, and suggestions. Thanks also for your patience, as I am obviously new here. Should I become knowledgeable enough to pay it forward at some time in the future, I will do so.
Check system logs - Windows System logs show no related errors. dump_errors(odrv0) also shows no errors. Is there someplace else I should be looking?
USB-UART converter? I have an arduino. I had hoped to get the motor(s) running before I had to figure that part out. I will go learn that and report back.
