Hi guys,
I am using AS5047P as my encoder, and I have successfully controlled the brushless motor by AS5047P without index signal. If I want to use AS5047P with index signal, do I need to set the value of the register of AS5047P? If so, which registers should be set? I’ve read the datasheet, but I have no idea.
No,you needn’t.
Follow this(https://docs.odriverobotics.com/encoders).
