How to solve this error (motor make beep sound but not moving)
Hello, I’m using Odrive3.6 24v and D5065 270KV motor with ATM10 Encdoer.
After motor and encoder configuration setup, I wrote the command “odrv0.axis1.requested_state = AXIS_STATE_MOTOR_CALIBRATION”.
The motor move very little and make the beep sound, but not move.
Can I solve this problem?
This is motor config
In [40]: odrv0.axis1.motor.config
Out[40]:
acim_slip_velocity: 14.706000328063965 (float)
current_control_bandwidth: 1000.0 (float)
current_lim: 10.0 (float)
direction: 0 (int32)
motor_type: 0 (int32)
phase_inductance: 1.5480663932976313e-05 (float)
phase_resistance: 0.09357212483882904 (float)
pole_pairs: 7 (int32)
pre_calibrated: False (bool)
requested_current_range: 60.0 (float)
torque_constant: 0.029999999329447746 (float)
torque_lim: inf (float)
Encoder Config
In [41]: odrv0.axis1.encoder.config
Out[41]:
abs_spi_cs_gpio_pin: 1 (uint16)
calib_scan_distance: 50.26548385620117 (float)
cpr: 8192 (int32)
find_idx_on_lockin_only: False (bool)
idx_search_unidirectional: False (bool)
mode: 0 (int32)
offset: 0 (int32)
offset_float: 0.0 (float)
use_index: False (bool)
zero_count_on_find_idx: True (bool)
Dump_errors(odrv0) :
In [43]: dump_errors(odrv0)
system: not found
axis: Error(s):
UNKNOWN ERROR: 0x00000100
motor: no error
encoder: Error(s):
ENCODER_ERROR_ILLEGAL_HALL_STATE
axis1
axis: no error
motor: no error
The test video : Odrive motor driver test - YouTube
Please, help me guys.
You may need capacitors (22nF) on the hall sensor inputs
EDIT: Wait, why are you using HALL encoder mode? That’s an Incremental encoder on the back of a motor that doesn’t have hall sensors. With the AMT10 encoder and the 5065 from the shop you can just do
odrv0.erase_configuration()
odrv0.axis1.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
Thank you, I solve the problem by your comments.
