How to wire a 3 phase hal sensor
I was using an Odrive S1 with a Neo 550 and I was unable to find how to wire the hall effects sensor into the Odrive s1
Hi! Halls connect to the HALL A / HALL B / HALL C pins, then 5V and GND for encoder power. If you have a motor thermistor, it can be connected on the THERMISTOR+ / THERMISTOR- pins.
