I need help solving encoder error cpr polepairs mismatch
i have two motors and one encoder (8192 cpr).
on motor (same encoder attached) - not working.
when on AXIS_STATE_FULL_CALIBRATION_SEQUENCE, the motor turns only in one direction) instead of both and on dump errors(odrv0,True) I get ENCODER_ERROR_CPR_POLEPAIRS_MISMATCH .
I have set odrv0.axis0.motor.config.pole_pairs = 7.
I have encoder.config.pre_calibrated set to True
I have tried setting odrv0.axis0.encoder.config.calib_range to 0.05 and 0.2 and 0.5 - no help there…
what else should I change to get it to work?
i have read everything i have found on this issue. made a save configuration and reboot.
Which encoder and motor is it specifically?
i use enconder CUIAMT10E2 and motor D5065-270KV
I looked up the CUI AMT10E2 and it says 5120 ppr, not 8192. This is likely to be your problem.
The CPR of AMT10E2 is 20480.
I’ve tried to change the cpr but still not working.
