Hi, i’m working on an Odrive Pro version and i try to control the velocity of a motor.
The motor I used is a BLDC motor with an Hall effect encoder. I connected the pins of the encoder on the ODrive Pro and the Motor phases but i have troubles with an illegal_hall_state error after encoder polarity callibration :
Also this motor was working correctly on the axes1 on the normal Odrive but result on an illegal_hall_state_error on axes0.
I read some topics on this type of errors but I don’t look one of that on the Odrive Pro. Thank you in advance for your response.
