I have an Odrive Pro and a 6374 motor I’m using for a +80m long tethered resistance machine. Basically a motorized spool with a string. Right now, I’m thinking of adjusting the min/max torque while in position mode to give resistance.
I have done some testing with a 6374 motor and it’s internal hall effect sensors with ODrive Pro. It spins! The web UI is becoming more intuitive too. But I have run into some cogging issues along with a few questions:
- I will have a lot of regen current. How do I make sure I don’t exceed the battery limits?
- Given the above, what else might go wrong that could overheat/fry the odrive i.e. what’s the ibus limit?
- When I run tests the ODrive gets pretty warm, is that normal?
- What else am I missing from the above (power wise)?
- I could add a more precise AMT encoder, but can I fix cogging with just the motor’s hall effect sensors?
I will likely be asking more questions after this
Thank you!
Sam
