I have original Odrive with firmware version 0.5.1.
Until today everything worked great. But today something is failing and I can not figure out what, hope you can give me some clues what am I doing wrong.
I do same procedure every time: 1. start full calibration, 2. check if everything is ok, 3. set to closed loop state, 4. change input_pos.
Motors goes over calibration sequence without issues - they are turning. In closed loop state they hold position as they should. But when I change input_pos, trying to control position, motors doesn’t turn, input_pos also stays the same.
Control mode is 3=“CONTROL_MODE_POSITION_CONTROL”
Input mode is 5=“INPUT_MODE_TRAP_TRAJ”
Config for trap_traj are the same as before:
vel_limit = 100.0 (float)
accel_limit = 100.0 (float)
decel_limit = 100.0 (float)
I am lost, tried almost everything except factory reset. Please help.
Full sequence log:
Connected to ODrive 206D39684D4D as odrv0
In [1]: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCEIn [2]: odrv0.axis1.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [3]: odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [4]: odrv0.axis1.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [5]: odrv0.axis0.controller.input_pos = 1
In [6]: odrv0.axis0.controller.input_pos = 5
In [7]: odrv0.axis0.controller.input_pos
Out[7]: 0.0055555556900799274In [8]: odrv0.axis0.controller.input_pos = 1
In [9]: odrv0.axis0.controller.input_pos
Out[9]: 0.0055555556900799274In [10]: dump_errors(odrv0)
axis: no error
motor: no error
fet_thermistor: no error
motor_thermistor: no error
axis1
axis: no error
motor: no error
