I think its python used by odrivetool, which you can find out by typing ‘sys.executable’ while running odrivetool. Actually I read the error again and might be just that script can’t find the compiler “arm-none-eabi-gcc.exe”. I am not sure where this is located on windows PC, or if you have it installed at all, but the folder containing gcc may need to be added to PATH as well. I think the error is from a shell script (bash in linux, not sure how this works in windows. cygwin?).
Getting the tool-chain properly configured was a nightmare for me too. I ended up compiling on linux.
Please confirm that the following commands don’t return errors (I included the versions I have):
make -v - 4.2.1 - https://chocolatey.org/packages/make
arm-none-eabi-gcc -v - 9.1 - http://www.freddiechopin.info/en/download/category/11-bleeding-edge-toolchain
tup -v - 0.7.8
python --version - 3.7.3
@naktamello and @Riewert
Okay, so I was able to get all of those commands to work in Git Bash but I am getting the same error when attempting to compile the firmware. This is the error that shows up
[ ETA~=??? Remaining=84 Active=8 ] 0%Unable to retrieve WOW64 info
tup error: failed to inject dll: No such file or directory
*** Command ID=360 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_usb.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Drivers_STM32F4xx_HAL_Driver_Src_stm32f4xx_ll_usb.c.o
l [e ETA~=??? Remaining=84 Active=7 ] 0%to retrieve WOW64 info
*** Command ID=364 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_tim_ex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Drivers_STM32F4xx_HAL_Driver_Src_stm32f4xx_hal_tim_ex.c.o
*** Command ID=362 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Src/tim.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Src_tim.c.o
*** Command ID=358 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pwr_ex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Drivers_STM32F4xx_HAL_Driver_Src_stm32f4xx_hal_pwr_ex.c.o
*** Command ID=354 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Src/stm32f4xx_hal_timebase_TIM.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Src_stm32f4xx_hal_timebase_TIM.c.o
*** Command ID=334 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cortex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Drivers_STM32F4xx_HAL_Driver_Src_stm32f4xx_hal_cortex.c.o
U [na ETA~=??? Remaining=84 Active=6 ] 0%ble to retrieve WOW64 info
*** Command ID=348 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ioreq.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc
-I. -IDrivers/DRV8301 -o build/obj/Board_v3_Middlewares_ST_STM32_USB_Device_Library_Core_Src_usbd_ioreq.c.o
U [na ETA~=??? Remaining=84 Active=5 ] 0%ble to retrieve WOW64 info
[ ETA~=??? Remaining=84 Active=2 ] 0% *** Command ID=356 failed: arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_can.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUART_PROTOCOL_ASCII -D__weak="__attribute__((weak))" -D__packed="__attribute__((__packed__))" -DUSE_HAL_DRIVER -DSTM32F405xx -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -Wall -Wdouble-promotion -Wfloat-conversion -fdata-sections -ffunction-sections -O2 -ffast-math -fno-finite-math-only -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/include -IBoard/v3/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Inc -IBoard/v3/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc -IBoard/v3/Drivers/STM32F4xx_HAL_Driver/Inc/Legacy -IBoard/v3/Drivers/CMSIS/Device/ST/STM32F4xx/Include -IBoard/v3/Drivers/CMSIS/Include -IBoard/v3/Inc -I. -IDrivers/DRV8301 -o build/obj/Board_v3_Drivers_STM32F4xx_HAL_Driver_Src_stm32f4xx_hal_can.c.o
[ ETA~=??? Remaining=84 Active=0 ] 0%
*** tup: 8 jobs failed.
make: *** [Makefile:14: all] Error 1
The terminal process terminated with exit code: 1
I went through the entire developer setup guide again to make sure everything was downloaded. I dont really know what is going wrong
Are you sure the versions of everything are either 64bit or 32bit? This can be difficult to check. I’m not sure which version is wiser to use.
“WOW64 is the x86 emulator that allows 32-bit Windows-based applications to run seamlessly on 64-bit Windows” - https://community.qlik.com/t5/QlikView-Deployment/Wow64-mode-Not-using-Wow64/td-p/755756
Also check this: Windows tool chain problem .
I don’t know if the 64-32bit was the issue. The second link was very helpful (thank you for that) as my security system was also removing tup32detect. Re-adding the file caused this:
* 83) arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_usb.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERS
arm-none-eabi-gcc: error: CreateProcess: No such file or directory
*** tup messages ***
*** Command ID=360 failed with return value 1
* 82) arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_can.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VER
*** Command ID=356 failed with return value 1
* 81) arm-none-eabi-gcc -std=c99 -c Board/v3/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ioreq.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6
*** Command ID=348 failed with return value 1
* 80) arm-none-eabi-gcc -std=c99 -c Board/v3/Src/stm32f4xx_hal_timebase_TIM.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUS
*** Command ID=354 failed with return value 1
* 79) arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pwr_ex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_
*** Command ID=358 failed with return value 1
* 78) arm-none-eabi-gcc -std=c99 -c Board/v3/Src/tim.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_VERSION_VOLTAGE=56 -DUSB_PROTOCOL_NATIVE -DUAR
*** Command ID=362 failed with return value 1
* 77) arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_tim_ex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_
*** Command ID=364 failed with return value 1
* 76) arm-none-eabi-gcc -std=c99 -c Board/v3/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_cortex.c -DHW_VERSION_MAJOR=3 -DHW_VERSION_MINOR=6 -DHW_
*** Command ID=334 failed with return value 1
[ ETA~=2s Remaining=76 Active=0 ] 9%
While trying to decipher the message a thought occurred to me. Is this an issue of the compiler not being able to find arm-none-eabi-gcc? If so, then is there a specific place I am supposed to put it? Because I have checked twice and this is the file path that is currently in my PATH: C:\Users\neelp\AppData\Roaming\xPacks\gnu-mcu-eclipse\arm-none-eabi-gcc
Try this: Arm-none-eabi-gcc: error: CreateProcess: No such file or directory . Also, make sure there are no special characters or spaces in any of your paths. Appearantly it is also possible that the paths are becoming too long.
As a side note, I ran into this exact same error when I tried using the wrong version of arm-none-eabi-gcc;
Note 2 : 8-2018-q4-major seems to have a bug on Windows. Please use 7-2018-q2-update. - https://docs.odriverobotics.com/developer-guide.html
You have also added a variable ARM_GCC_ROOT to your environment variables right?
This is what Git Bash shows me. I am fairly certain that this means I have everything that I need for arm-none-eabi-
I will look into the length of paths by shortening them.
I completely missed that line about gcc version. After testing the PATH length thing I will try that too.
Yes I followed the directions to add ARM_GCC_ROOT.
Although, I have it in a different folder. Does it matter where I have the folder? mine is just in the program files (x86) folder.
The folder shouldn’t matter
I meant the last post, about trying a clean clone. Who knows, there might be some obscure setting somewhere that is still pointing to the wrong place.
Okay so, I shortened the paths (and made sure there were no special characters): same error
I uninstalled the 8-2018-q4-major and installed 7-2018-q2-update (I also updated all the paths to account for the change): same error
What does it mean to do a clean clone? Because that is the last thing that I haven’t tried. I am also going to go through my paths again and make sure everything is lined up correctly.
It means to remove all the files you downloaded from github for the ODrive firmware and download again. Also it can be useful to try a few of the popular branches instead of Master. Ones that I work with are https://github.com/madcowswe/ODrive/tree/devel and https://github.com/Wetmelon/ODrive/tree/RazorsEdge. Try compiling one of those. I use gitkraken to switch between branches.
Thanks guys,
This thread was exactly what I needed to fix my similar issues!
Thank you so much @Riewert
The firmware compiles now. Now to figure out why the flash task is failing in VSCode lol.
Just a brief question. Now that the Firmware compiles it is making a file called “ODriveFirmware.hex” in the ‘build’ folder. Is this the file that I would flash using odrivetool dfu (file path)? Or do I have to wait for make flash to work?
@Lewis_Siempelkamp no problem. Hopefully this will help others avoid the problems that I am going through. Although all credit to Riewert and naktamello, I sort of just asked questions lol.
Glad you were able to make it work! yes the hex file is the firmware binary. Other tools(openocd and ST-Link utility) lets you use .elf file or .bin file as well. If you don’t have a st-link already I highly recommend you get one (debugging purposes).
Good to know.
Thanks so much, @naktamello, I will look into getting an ST-link. Is this something that would work? Or is there a specific one that works best?
They all work the same, so getting a cheapo from aliexpress (or ODrive store) may be a better option. Sometimes the chip may be put into a state you can’t recover with only dfu, so another reason to get one! anyways good luck with your adventure.
FYI I never was able to get the dfu tool working on windows 10. The stl link was painless, though
I hooked up the st-link incorrectly to my board once, and now I may have burnt out one of the pins, so I can only use DFU on one board. To prevent this from happening again, I prefer to use the DFU tool unless debugging is necessary (has not been yet).
Hmm any tips on getting the DFU tool working on windows 10 - I gave up and haven’t gone back since trying the ST-Link with success.
If I’m not mistaken in the ODrivetool you will see that it is switching to DFU mode, and then it never checks back in again.
When the ODrive switches to DFU mode I think you need to configure the driver in Zadiq tool again (should only be necessary the first time). I’m not sure, and I can’t check because I’m at work, but I believe in DFU mode it is recognized as a different device and the driver is switched out of libusb or something.
That was what was happening to me. I followed the directions on how to Upgrade firmware with a different DFU tool and that worked well. After that I didn’t have any major issues with the dfu tool.
