Hello there
I am currently in the process of developing a native Linux driver for the ODrive, because I want to learn to develop drivers and this seems like a great device to do so for.
But I’m not getting an response from the ODrive. I’ve flashed the V3.6 firmware to the device.
When I analyze the traffic in wireshark I can see that the packets match. But when I open an debug session via the ST Link to the Odrive I noticed that the packet that is processed only contains NULL.
The following hex dump is a working packet from the odrivetool
USB URB
[Source: host]
[Destination: 2.5.3]
URB id: 0xffff9925fbe7c6c0
URB type: URB_SUBMIT (‘S’)
URB transfer type: URB_BULK (0x03)
Endpoint: 0x03, Direction: OUT
Device: 5
URB bus id: 2
Device setup request: not relevant (’-’)
Data: present (0)
URB sec: 1564506936
URB usec: 66928
URB status: Operation now in progress (-EINPROGRESS) (-115)
URB length [bytes]: 12
Data length [bytes]: 12
[Response in: 41]
[bInterfaceClass: Device (0x00)]
Unused Setup Header
Interval: 0
Start frame: 0
Copy of Transfer Flags: 0x00000000
Number of ISO descriptors: 0
0000 c0 c6 e7 fb 25 99 ff ff 53 03 03 05 02 00 2d 00
0010 38 7b 40 5d 00 00 00 00 70 05 01 00 8d ff ff ff
0020 0c 00 00 00 0c 00 00 00 00 00 00 00 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040 81 00 00 80 00 02 00 00 00 00 01 00
This is my packet
USB URB
[Source: host]
[Destination: 2.8.3]
URB id: 0xffff96daaf3efbc0
Device: 8
URB bus id: 2
Data: present (0)
URB sec: 1564653447
URB usec: 377160
[Response in: 6]
[bInterfaceClass: Unknown (0xffff)]
Unused Setup Header
Interval: 0
Start frame: 0
0000 c0 fb 3e af da 96 ff ff 53 03 03 08 02 00 2d 00
0010 87 b7 42 5d 00 00 00 00 48 c1 05 00 8d ff ff ff
0040 81 00 00 80 40 00 00 00 00 00 01 00
The destination is different because I disconnected and reconnected the device between captures.
As you can see the packets are identical and I get an URB_Complete right after it.
To submit the packet from my driver I use the usb_bulk_msg call.
Anybody got any suggestions or ideas?
Kind regards
