Hi All, I’ve always had trouble running liveplotter on my ODrivetool installation and curious if I could get some feedback. I have the same error as below running the liveplotter command from the command line or in the ODrivetool CLI. This error appears and a python icon opens in my OSX Dock attempting to launch, but not much more than that happens. As title implies this is a straight install from the command line without the use of anaconda. Using ODrive control utility v0.5.1
In [106]: start_liveplotter(lambda: [odrv0.axis0.encoder.pos_estimate])
Out[106]: <fibre.utils.Event at 0x110b577f0>
In [107]: 2020-12-31 13:49:21.383 Python[29280:5258855] WARNING: NSWindow drag regions should only be invalidated on the Main Thread! This will throw an exception in the future. Called from (
0 AppKit 0x00007fff35f1c607 -[NSWindow(NSWindow_Theme) _postWindowNeedsToResetDragMarginsUnlessPostingDisabled] + 378
1 AppKit 0x00007fff35f199f7 -[NSWindow _initContent:styleMask:backing:defer:contentView:] + 1479
2 AppKit 0x00007fff35f1942a -[NSWindow initWithContentRect:styleMask:backing:defer:] + 45
3 _macosx.cpython-37m-darwin.so 0x000000010ebb66b0 -[Window initWithContentRect:styleMask:backing:defer:withManager:] + 80
4 _macosx.cpython-37m-darwin.so 0x000000010ebb9bc7 FigureManager_init + 327
5 Python 0x00000001066f0f23 wrap_init + 12
6 Python 0x00000001066b7cd9 wrapperdescr_call + 337
7 Python 0x00000001066b1dd8 _PyObject_FastCallKeywords + 378
8 Python 0x000000010674a6f9 call_function + 521
9 Python 0x0000000106747437 _PyEval_EvalFrameDefault + 28173
10 Python 0x00000001066b2380 function_code_fastcall + 116
11 Python 0x00000001066b2cf2 _PyObject_Call_Prepend + 143
12 Python 0x00000001066f0e91 slot_tp_init + 80
13 Python 0x00000001066eda7e type_call + 178
14 Python 0x00000001066b1dd8 _PyObject_FastCallKeywords + 378
15 Python 0x000000010674a6f9 call_function + 521
16 Python 0x0000000106747437 _PyEval_EvalFrameDefault + 28173
17 Python 0x00000001066b2380 function_code_fastcall + 116
18 Python 0x000000010674a873 call_function + 899
19 Python 0x0000000106747437 _PyEval_EvalFrameDefault + 28173
20 Python 0x000000010674b0af _PyEval_EvalCodeWithName + 1898
21 Python 0x00000001066b1bae _PyFunction_FastCallDict + 493
22 Python 0x00000001066b2cf2 _PyObject_Call_Prepend + 143
23 Python 0x00000001066b20b1 PyObject_Call + 136
24 Python 0x00000001067477f7 _PyEval_EvalFrameDefault + 29133
25 Python 0x000000010674b0af _PyEval_EvalCodeWithName + 1898
26 Python 0x00000001066b1f68 _PyFunction_FastCallKeywords + 248
27 Python 0x000000010674a873 call_function + 899
28 Python 0x0000000106747437 _PyEval_EvalFrameDefault + 28173
29 Python 0x000000010674b0af _PyEval_EvalCodeWithName + 1898
30 Python 0x00000001066b1bae _PyFunction_FastCallDict + 493
31 Python 0x00000001067477f7 _PyEval_EvalFrameDefault + 29133
32 Python 0x00000001066b2380 function_code_fastcall + 116
33 Python 0x000000010674a873 call_function + 899
34 Python 0x000000010674741d _PyEval_EvalFrameDefault + 28147
35 Python 0x00000001066b2380 function_code_fastcall + 116
36 Python 0x000000010674a873 call_function + 899
37 Python 0x000000010674741d _PyEval_EvalFrameDefault + 28147
38 Python 0x00000001066b2380 function_code_fastcall + 116
39 Python 0x00000001066b2cf2 _PyObject_Call_Prepend + 143
40 Python 0x00000001066b20b1 PyObject_Call + 136
41 Python 0x00000001067b0a99 t_bootstrap + 71
42 libsystem_pthread.dylib 0x00007fff64a402eb _pthread_body + 126
43 libsystem_pthread.dylib 0x00007fff64a43249 _pthread_start + 66
44 libsystem_pthread.dylib 0x00007fff64a3f40d thread_start + 13
2020-12-31 13:49:21.598 Python[29280:5258855] WARNING: nextEventMatchingMask should only be called from the Main Thread! This will throw an exception in the future.
Hope someone can help out with this
