Low torque issue with ODrive
I am working on a mobile robot and using ODrive to control four 170KV motors for the drivetrain.
My current setup is as follows:
  • 4 ODrive s1
  • 4 motors
  • Motor KV: 170KV
  • Robot weight: about 20 kg
  • Supply voltage: 24 V
  • Gear ratio: 1:1
  • Control mode: Velocity control
The problem is that the robot sometimes seems to have insufficient torque, especially under load.
I would like to ask:
  1. Are there any ODrive settings that can help increase torque output?
  2. Are there any recommended tuning methods in ODrive GUI for this kind of setup?
  3. In velocity control, which parameters should I adjust to improve low-speed torque and startup performance?
Since my encoder is attached to the wheel side, the gear ratio is effectively 1:1 for control.
If anyone has experience with similar heavy robots, I would really appreciate your advice.
Thank you.
Have you gone through tuning the controller? And what’s your motor current limit set to?
The tuning has already been completed.
Is there anything I can adjust in the GUI settings?
Well, there’s plenty of things that can be done to increase current limits / etc. But more importantly is seeing if you’re hitting the ODrive’s current limits – if you’re in the GUI, what’s the current going to under load? With python/odrivetool/can this would be Iq_setpoint/Iq_measured.
