M1 briefly turn then stop working
I was able to setup my hoverboard motor for M1.
My setup as below
In [25]: dev0.axis1.motor
Out[25]:
DC_calib_phA: 1.317206859588623 (float)
DC_calib_phB: -0.8186456561088562 (float)
DC_calib_phC: -0.4985051453113556 (float)
I_bus: 1.06131911277771 (float)
config:
  I_bus_hard_max: inf (float)
  I_bus_hard_min: -inf (float)
  R_wL_FF_enable: False (bool)
  bEMF_FF_enable: False (bool)
  current_lim: 10.0 (float)
  motor_type: 0 (uint8)
  phase_inductance: 0.00022225403517950326 (float)
  phase_resistance: 0.164923295378685 (float)
  pole_pairs: 52 (int32)
  pre_calibrated: True (bool)
  requested_current_range: 25.0 (float)
  resistance_calib_max_voltage: 4.0 (float)
  torque_constant: 0.515999972820282 (float)
  torque_lim: inf (float)
current_control:
  Ialpha_measured: 0.4154595136642456 (float)
  Ibeta_measured: 10.034153938293457 (float)
  Id_measured: 0.06779196858406067 (float)
  Id_setpoint: 0.0 (float)
  Iq_measured: 10.024621963500977 (float)
  Iq_setpoint: 10.0 (float)
  Vd_setpoint: 0.0 (float)
  Vq_setpoint: 0.0 (float)
  final_v_alpha: 0.10449008643627167 (float)
  final_v_beta: 1.6750462055206299 (float)
  i_gain: 16.49233055114746 (float)
  p_gain: 0.022225404158234596 (float)
  phase: -0.020852088928222656 (float)
  phase_vel: 0.0 (float)
  power: 25.193851470947266 (float)
  v_current_control_integral_d: 0.07110793888568878 (float)
  v_current_control_integral_q: 1.677383542060852 (float)
current_meas_phA: 0.2547496557235718 (float)
current_meas_phB: 8.471807479858398 (float)
current_meas_phC: -8.726564407348633 (float)
error: 0 (uint64)
fet_thermistor:
  config: ...
  temperature: 32.67342758178711 (float)
is_armed: True (bool)
is_calibrated: True (bool)
last_error_time: 0.0 (float)
motor_thermistor:
  config: ...
  temperature: 0.0 (float)
n_evt_current_measurement: 103708 (uint32)
n_evt_pwm_update: 103711 (uint32)
The encoder setup is as below
In [26]: dev0.axis1.encoder
Out[26]:
config:
  abs_spi_cs_gpio_pin: 1 (uint16)
  bandwidth: 350.0 (float)
  calib_scan_distance: 520.0 (float)
  cpr: 312 (int32)
  direction: 1 (int32)
  find_idx_on_lockin_only: False (bool)
  hall_polarity: 0 (uint8)
  hall_polarity_calibrated: True (bool)
  index_offset: 0.0 (float)
  mode: 1 (uint16)
  phase_offset: 254 (int32)
  phase_offset_float: 0.5199145674705505 (float)
  use_index: False (bool)
  use_index_offset: True (bool)
count_in_cpr: 2 (int32)
delta_pos_cpr_counts: -5.605193857299268e-45 (float)
error: 0 (uint16)
hall_state: 2 (uint8)
index_found: False (bool)
interpolation: 0.5 (float)
is_ready: True (bool)
pos_abs: 0 (int32)
pos_circular: 0.009337152354419231 (float)
pos_cpr_counts: 2.913195848464966 (float)
pos_estimate: 0.00933716632425785 (float)
pos_estimate_counts: 2.913195848464966 (float)
shadow_count: 2 (int32)
spi_error_rate: 0.0 (float)
vel_estimate: 0.0 (float)
vel_estimate_counts: 0.0 (float)
I see no errors and when tried to turn the motor by entering
dev0.axis1.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
dev0.axis1.controller.input_vel = 2
The motor turns quite fast then stop working.
After this motor returns error as below
error: 16777216 (uint64)
What am I doing wrong?
Any suggestions?
