For our senior project, we are using Ali Express v3.6 56V ODrives on version 0.5.1. They connect to odrivetool fine on my computer, but we have been having an issue with the M1 on all of them acting aggressive (video below is of the startup sequence). The odrivetool is not showing any errors when the motor is spinning, like in the video.
We are finding the index automatically through the config on the Drive, but we are putting into closed loop through Arduino code. The point of this was to avoid a problem with missing the index before putting into closed loop and causing it to also act strange.
Any help would be very appreciated, thanks.
At what point does it do this strange maneuver?
0.5.1 is quite old…
It happens after the motors go into closed loop.
It seems that we are having some errors trying to update the firmware. Any tips on updating them?
I have some makerbase v3.6 Odrives as well and the M1 on both of them are non-function. Not entirely sure why but everything goes smoothly except if I try to go into closed loop control where it seems to work for a little bit before instantly spinning up to max set current and throwing and error. I am not entirely sure what may be causing it, but I am going to add some capacitors to the encoder pins to see if it is a noise issue.
Hmm, yeah I’m not surprised the makerbase ones are nonfunctional unfortunately. I’d get your money back if possible.
