i’m running a ODrive card(v3.5) with firmware 0.5.4, and I’m having issues with calibrating a hub-motor.
This one to be exact: 8 inch brushless single shaft encoder hub motor - UU Motor
I have plugged in A,B,C phases and also the hall-encoder wires onto M0 on my odrive card.
Motor calibration works fine, here is the config after i run that:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_control_bandwidth: 1000.0 (float)
current_lim: 10.0 (float)
motor_type: 0 (uint8)
phase_inductance: 0.00026390718994662166 (float)
phase_resistance: 0.15721480548381805 (float)
pole_pairs: 15 (int32)
pre_calibrated: False (bool)
requested_current_range: 60.0 (float)
resistance_calib_max_voltage: 4.0 (float)
torque_constant: 0.03999999910593033 (float)
torque_lim: inf (float)
But when i run a FULL_CALIBRATION or a ENCODER_OFFSET_CALIBRATION i get a mismatch on cpr to polepairs
odrv0.axis0.requested_state = AXIS_STATE_ENCODER_OFFSET_CALIBRATION```
the wheel only spins oneway and dump_errors gives me:
system: no error
axis: no error
motor: no error
encoder: Error(s):
ENCODER_ERROR_CPR_POLEPAIRS_MISMATCH
axis1
axis: no error
motor: no error
So my first question is cpr should be set to 90? 15*6 ?
Could there be any other issues with my conf?
encoder.config:
abs_spi_cs_gpio_pin: 1 (uint16)
calib_scan_distance: 50.26548385620117 (float)
cpr: 90 (int32)
direction: 1 (int32)
find_idx_on_lockin_only: False (bool)
hall_polarity: 0 (uint8)
hall_polarity_calibrated: False (bool)
index_offset: 0.0 (float)
mode: 0 (uint16)
phase_offset: -15 (int32)
phase_offset_float: -0.14545565843582153 (float)
use_index: False (bool)
use_index_offset: True (bool)
controller config:
anticogging:
anticogging_enabled: True (bool)
calib_anticogging: False (bool)
calib_pos_threshold: 1.0 (float)
calib_vel_threshold: 1.0 (float)
cogging_ratio: 1.0 (float)
index: 0 (uint32)
axis_to_mirror: 255 (uint8)
control_mode: 3 (uint8)
electrical_power_bandwidth: 20.0 (float)
enable_torque_mode_vel_limit: True (bool)
enable_vel_limit: True (bool)
homing_speed: 0.25 (float)
inertia: 0.0 (float)
input_mode: 1 (uint8)
load_encoder_axis: 0 (uint8)
mechanical_power_bandwidth: 20.0 (float)
mirror_ratio: 1.0 (float)
pos_gain: 20.0 (float)
spinout_electrical_power_threshold: 10.0 (float)
spinout_mechanical_power_threshold: -10.0 (float)
steps_per_circular_range: 1024 (int32)
torque_mirror_ratio: 0.0 (float)
torque_ramp_rate: 0.009999999776482582 (float)
vel_gain: 0.1666666716337204 (float)
vel_integrator_gain: 0.3333333432674408 (float)
vel_integrator_limit: inf (float)
vel_limit: 2.0 (float)
vel_limit_tolerance: 1.2000000476837158 (float)
vel_ramp_rate: 1.0 (float)
Thankful for any input at all! I’ll happily add more logs if there is any missing
