I’ve succesfully configured my ODrive and motor, I’ve run the full calibration sequence and that motor rotated a little as expected. Bit now when I want to put it in closed loop control it does nothing, lituarly nothing
Cheers Stijn
Cheers Stijn
0x101
Cheers Stijn
Can you , please, share odrv0.axis0?
Thanks
ODrive control utility v0.4.1
Please connect your ODrive.
Connected to ODrive 206435823748 as odrv0
In [1]: odrv0
Out[1]:
vbus_voltage = 29.69677734375 (float)
serial_number = 206435823748 (int)
hw_version_major = 3 (int)
hw_version_minor = 5 (int)
hw_version_variant = 48 (int)
fw_version_major = 0 (int)
fw_version_minor = 4 (int)
fw_version_revision = 1 (int)
fw_version_unreleased = 0 (int)
user_config_loaded = True (bool)
brake_resistor_armed = True (bool)
system_stats:
uptime = 57958 (int)
min_heap_space = 18264 (int)
min_stack_space_axis0 = 7868 (int)
min_stack_space_axis1 = 7868 (int)
min_stack_space_comms = 8468 (int)
min_stack_space_usb = 700 (int)
min_stack_space_uart = 3932 (int)
min_stack_space_usb_irq = 1820 (int)
min_stack_space_startup = 564 (int)
usb: ...
i2c: ...
config:
brake_resistance = 2.0 (float)
enable_uart = True (bool)
enable_i2c_instead_of_can = False (bool)
enable_ascii_protocol_on_usb = True (bool)
dc_bus_undervoltage_trip_level = 8.0 (float)
dc_bus_overvoltage_trip_level = 51.840003967285156 (float)
axis0:
error = 0x0000 (int)
current_state = 1 (int)
requested_state = 0 (int)
loop_counter = 464770 (int)
config: ...
motor: ...
controller: ...
encoder: ...
sensorless_estimator: ...
axis1:
loop_counter = 464797 (int)
config: ...
motor: ...
controller: ...
encoder: ...
can:
node_id = 0 (int)
TxMailboxCompleteCallbackCnt = 0 (int)
TxMailboxAbortCallbackCnt = 0 (int)
received_msg_cnt = 0 (int)
received_ack = 0 (int)
unexpected_errors = 0 (int)
unhandled_messages = 0 (int)
test_property = 0 (int)
test_function(delta: int)
get_oscilloscope_val(index: int)
get_adc_voltage(gpio: int)
save_configuration()
erase_configuration()
reboot()
enter_dfu_mode()
In [2]: odrv0.axis1
Out[2]:
loop_counter = 3757912 (int)
config:
counts_per_step = 2.0 (float)
ramp_up_time = 0.4000000059604645 (float)
ramp_up_distance = 12.566370964050293 (float)
spin_up_current = 10.0 (float)
spin_up_acceleration = 400.0 (float)
spin_up_target_vel = 400.0 (float)
motor:
armed_state = 0 (int)
is_calibrated = False (bool)
current_meas_phB = 0.10494136810302734 (float)
current_meas_phC = 0.11910498142242432 (float)
DC_calib_phB = -1.5147298574447632 (float)
DC_calib_phC = -1.6897022724151611 (float)
phase_current_rev_gain = 0.02500000037252903 (float)
current_control: ...
gate_driver: ...
timing_log: ...
config: ...
controller:
pos_setpoint = 0.0 (float)
vel_setpoint = 0.0 (float)
vel_integrator_current = 0.0 (float)
config: ...
set_pos_setpoint(pos_setpoint: float, vel_feed_forward: float, current_feed_forward: float)
encoder:
is_ready = False (bool)
index_found = False (bool)
shadow_count = 1 (int)
count_in_cpr = 1 (int)
offset = 0 (int)
interpolation = 0.5 (float)
phase = 0.041233405470848083 (float)
pos_estimate = 1.7666125297546387 (float)
pos_cpr = 1.7666125297546387 (float)
hall_state = 6 (int)
pll_vel = 0.0 (float)
pll_kp = 2000.0 (float)
pll_ki = 1000000.0 (float)
config: ...
phase = 0.06248487904667854 (float)
pll_pos = 0.062166016548871994 (float)
pll_vel = 0.10584936290979385 (float)
cheers Stijn
