Hi all,
So I’ve sucessfully calibrated both hall sensors and my hoverboard style motor without errors, however I’m getting the following error from odrive0.axis0.motor when testing closed loop control via setting velocity commands:
16777216 (uint16)
which converts to the hex code error:
0x01000000 which looks like a system error from the motor
I first enter these commands:
odrv0.axis0.controller.input_vel = 2
The motor moves for 1-2 seconds and stops.
This is the output from: odrv0.axis0.motor
DC_calib_phA: -0.4268602430820465 (float)
DC_calib_phB: 0.2320336103439331 (float)
DC_calib_phC: 0.1948387771844864 (float)
I_bus: 0.0 (float)
config:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
current_lim: 10.0 (float)
motor_type: 0 (uint8)
phase_inductance: 0.0004522507661022246 (float)
phase_resistance: 0.19346265494823456 (float)
pole_pairs: 15 (int32)
pre_calibrated: True (bool)
requested_current_range: 25.0 (float)
resistance_calib_max_voltage: 4.0 (float)
torque_constant: 0.4650000035762787 (float)
torque_lim: inf (float)
current_control:
Ialpha_measured: -3.7667298316955566 (float)
Ibeta_measured: -3.2100861072540283 (float)
Id_measured: 4.904476642608643 (float)
Id_setpoint: 0.0 (float)
Iq_measured: 0.6619045734405518 (float)
Iq_setpoint: 6.379796504974365 (float)
Vd_setpoint: 0.0 (float)
Vq_setpoint: 0.0 (float)
final_v_alpha: 1.713279366493225 (float)
final_v_beta: -1.2373284101486206 (float)
i_gain: 19.34626579284668 (float)
p_gain: 0.045225076377391815 (float)
phase: -2.046341896057129 (float)
phase_vel: 0.0 (float)
power: -3.7148144245147705 (float)
v_current_control_integral_d: -0.5606003999710083 (float)
v_current_control_integral_q: 1.8080379962921143 (float)
current_meas_phA: 0.4287026822566986 (float)
current_meas_phB: -0.23318833112716675 (float)
current_meas_phC: -0.19548656046390533 (float)
error: 16777216 (uint64)
fet_thermistor:
config: ...
temperature: 31.7919921875 (float)
is_armed: False (bool)
is_calibrated: True (bool)
last_error_time: 171.6840057373047 (float)
motor_thermistor:
config: ...
temperature: 0.0 (float)
n_evt_current_measurement: 6251047 (uint32)
n_evt_pwm_update: 6251061 (uint32)
I should also add, if I change axis state to idle, and back to closed loop, I am able to once again enter a velocity which causes the motor to once again move for a second before stopping.
EDIT: I just ran dump_errors(odrv0) and got the following:
ODRIVE_ERROR_DC_BUS_OVER_REGEN_CURRENT
A quick search doesnt quite show any direct solutions for solving this.
I am running off of a 56v battery that was used on a segway.
