MOTOR_ERROR_DRV_FAULT and cant enter in dfu mode
Good morning, I have a problem with my odrive v 3…6 which I initially configured following the guide: Getting Started — ODrive Documentation 0.0 documentation
configuring it for a brushless motor of 1000w at 48vdc with incremental encoder but wanting to execute the line:
it does not move and if I execute the line:
dump_errors(odrv0)
I get:
In [19]: dump_errors(odrv0)
system: no error
axis: no error
motor: Error(s):
axis1
axis: no error
motor: Error(s):
try to clear the settings and reconfigure but always I get the same error
Try to enter DFU mode believing that maybe you do not have the correct version but whenever I execute I get::
$ odrivetool dfu
ODrive control utility v0.5.4
Waiting for ODrive...
Found ODrive 335C365E3539 (v3.6-56V) with firmware v0.5.4-dev
Checking online for newest firmware... found v0.5.4
Warning: you are about to flash firmware v0.5.4 which is older than the firmware on the device (v0.5.4-dev).
Downloading firmware v0.5.4...
Saving configuration to /tmp/odrive-config-335C365E3539.json...
The file /tmp/odrive-config-335C365E3539.json already exists. Do you want to override it? [Y/n] y
Configuration saved.
Putting device 335C365E3539 into DFU mode...
found device but could not check serial number (retrying in 1s)
any idea how i can solve the problem?
Where did you get this device?
from the official page, I bought 2, today I tried the other one and it seems to work without problems, I don’t know what could be happening if they both have the same configuration
