I experimented with applying a load to the motor to generate a high current, and as a result, a current of 100A momentarily flowed. After that, when I tried to run the calibration, it went to MOTOR_ERROR_DRV_FAULT. Is there any way to solve this problem?
You may have a damaged board, unfortunately. I assume this is a problem even after powering down and up?
