I would like help figuring out why odrive is failing is a very specific scenario. I am using odrive (v3.6-56V) operating at 36V (i am using a battery).
MOTOR: Electric Skateboard Brushless Motor 6374 190KV | Longboard | Flipsky – FLIPSKY
ENCODER: 8192 CPR Encoder with ODrive Cable — ODrive
Limits:
- odrv0.axis0.motor.config.torque_lim = 1.5
- odrv0.axis0.motor.config.current_control_bandwidth = 2000
- odrv0.axis0.controller.config.vel_limit = 50
- odrv0.axis0.controller.config.input_mode = INPUT_MODE_PASSTHROUGH
- odrv0.axis0.controller.config.control_mode = CONTROL_MODE_POSITION_CONTROL
The error is happens only in a very specific scenario. When i command odrive the following commands in the following order in very short time span.
odrv0.axis0.controller.input_pos = -150
odrv0.axis0.controller.input_pos = 0
I would like to note that:
- This error never happens if I reduced the torque limit from 1.5 to 1.3N.m
- This error never happens if I waited for the motor to reach position -150 before commanding position 0, and waiting for the motor to reach position 0 before commanding it to go to position -150, etc …
- I did try to reduce the noise on the encoder index signal by shielding the encoder cable and adding a 47nF cap between the encoder index signal and GND.
- i did reduce the length of the encoder cable as much as possible and i am running it away from the motor phase cables.
I would love any suggestions of what i can try next
Thank you
