After I turn on my Odrive 3.5 and go through calibration and enter closed loop control if I then use pos_setpoint the motor soesn’t respond but there are no errors. If I then try to turn the shaft of the motor the motor fails with errors. I have just updated the firmware from the original version and updated odrivetool, the motor worked before the update with the original firmware. Is there some incompatibility in my settings? How do I clear configuration?
In [112]: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE
In [113]: odrv0.axis0.requested_state = AXIS_STATE_CLOSED_LOOP_CONTROL
In [114]: dump_errors(odrv0)
axis: Error(s):
ERROR_CONTROLLER_FAILED
motor: Error(s):
ERROR_CONTROL_DEADLINE_MISSED
controller: Error(s):
ERROR_OVERSPEED
axis1
axis: no error
motor: no error
This is the configuration
In [120]: odrv0.axis0.config
Out[120]:
counts_per_step = 2.0 (float)
step_gpio_pin = 1 (int)
dir_gpio_pin = 2 (int)
lockin:
current = 10.0 (float)
ramp_time = 0.4000000059604645 (float)
ramp_distance = 3.1415927410125732 (float)
accel = 20.0 (float)
vel = 40.0 (float)
finish_distance = 100.0 (float)
finish_on_vel = False (bool)
finish_on_distance = False (bool)
finish_on_enc_idx = False (bool)
