This is the config I have been setting prior to initial start up:
→ Plug in
erase_configuration()
dump_errors(odrv0)
odrv0.axis0.clear_errors()
odrv0.axis1.clear_errors()
odrv0.axis0.encoder.config.cpr = 4000
odrv0.axis1.encoder.config.cpr = 4000
odrv0.axis0.motor.config.pole_pairs = 20
odrv0.axis1.motor.config.pole_pairs = 20
odrv0.axis0.motor.config.torque_constant = 8.27/90
odrv0.axis1.motor.config.torque_constant = 8.27/90
odrv0.axis0.controller.config.pos_gain = 60
odrv0.axis1.controller.config.pos_gain = 60
odrv0.axis0.controller.config.vel_gain = 0.1
odrv0.axis1.controller.config.vel_gain = 0.1
odrv0.axis0.controller.config.vel_integrator_gain = 0.2
odrv0.axis1.controller.config.vel_integrator_gain = 0.2
import math
odrv0.axis0.controller.config.vel_limit = math.inf
odrv0.axis1.controller.config.vel_limit = math.inf
odrv0.axis1.requested_state = AXIS_STATE_MOTOR_CALIBRATION
odrv0.axis0.requested_state = AxisState.ENCODER_INDEX_SEARCH
odrv0.axis1.requested_state = AxisState.ENCODER_INDEX_SEARCH
odrv0.axis0.requested_state = AxisState.ENCODER_OFFSET_CALIBRATION
odrv0.axis1.requested_state = AxisState.ENCODER_OFFSET_CALIBRATION
odrv0.axis0.config.startup_encoder_index_search = True
odrv0.axis1.config.startup_encoder_index_search = True
odrv0.axis1.encoder.config.pre_calibrated = True
odrv0.axis1.config.startup_closed_loop_control = True
odrv0.save_configuration()
odrv0.reboot()
