Motor Selection - Will Turnigy Aerodrive SK3 - 5065-275kv work with 24V Odrive?
Hi I am really new to all this.
I’ve recently purchased an 24V ODrive v3.6.
I’ve been trying to source motors using the ODrive Motor Guide
The motor I would like to use (Turnigy Aerodrive SK3 - 4250-350kv) is out of stock at Hobbyking.
Max Current is 50A and Max Voltage is 20V so I assume this should work with the 24V ODrive
The next motor that I am looking at is (Turnigy Aerodrive SK3 - 5065-275kv) is in stock at Hobbyking. The Max current and Max Voltage of this motor is 60A and 40V. So voltage is obviously higher than 24V.
Would I be still able to using this motor with the 24V Odrive or should I source another motor that is more suitable?
My application is a low speed 60 RPM, low(ish) torque, 2 feet radius positioning arm moving a 0.5kg load. Sort of like the hour hand of a clock.
Thank you for any feedback!
It will work fine at the lower voltage.
