I am driving the motor in sensorless velocity control mode.
When I drive the motor above 100rpm everything is fine, but when I go below that, or stop the motor I am occasionally unable to return to speed (about 1/3 of the time). Restarting sensorless mode will resolve the issue and bring the motor back to speed.
I understand that sensorless mode has trouble with velocity control below 100rpm, and I dont need to drive slower than that, but I should be able to stop the motor and have it go back to speed on command without having to re-start sensorless mode. .
I have found that if I try to reverse the direction of the target velocity then it will get out of the stall (ie if I’m at 0rpm, I try to go to 1000rpm but the motor doesn’t do so, I then go to -1000 rpm and everything is fine).
Let me know if you need any details of my motor and I can provide it.
