I am trying to move to a set point.
I can set the set point and velocity using the stream method.
However the motor does not stop at the set point.
If I change to POSITION_CONTROL the motor stops and stay at this position.
Any suggestions?
Any suggestions?
Sorry, can you elaborate on the issue? What control mode and input mode are you using? If you’re commanding a nonzero velocity feedforward, the ODrive will attempt to continue past the setpoint.
I start with the control mode VELOCITY_CONTROL and input mode VEL_RAMP.
If I set a velocity and a set point the axis continues.
If I change the control mode to POSITION_CONTROL it freezes at the current position.
Current state is CLOSED_LOOP_CONTROL
The input vel is 3.
Please explain the velocity feed forward?
Velocity feedforward is for streaming precomputed trajectories, see here: Controller — ODrive Documentation 0.6.11 documentation
If you’re just trying to move between positions, the best option is to use trajectory control mode. But maybe I’m misunderstanding what you’re trying to do?
I got it up and running.
Now I can move forward investigating other parameters.
Thanks.
PS: How can I tag the topic as solved?
Great to hear! I don’t think we have a way of tagging it as solved, that would be a good idea to add!
