Negative offset float during encoder calibration
Hi All,
I tried to connect hoverboard wheels to odrive v3.6 56V.
Ater setting all the parameters according to the hoverboard guide and replacing CTRL_MODE_VELOCITY_CONTROL with CTRL_MODE_CURRENT_CONTROL , also adding 47mF capacitors to M1.(with 22mF capacitors to both motor phases the same issue observed).
While im calibrate the encoder offset on M0 after the comment:
odrv0.axis0.encoder
I got negative offset float only on M0 with no errors.
error = 0x0000 (int)
offset_float = -0.483556701278687 (float)
After several failed attempts to get positive value
(should be close to 0.5 or 1.5 ) i decided to continue with this parameter to the next step but then only one motor spin and i got error.
Does anyone encoutered this problem and can help me solve it?
Setup:
ODrive v3.6 56V
2*300 Watt 36V dual motors system
4.3AH lithium battery
Thanks,
RG.
Hey, i had the same problem. my solution was to change the first and the last HALL sensor (a and z). i have two motors and the first was no problem but the second one made the smae problems like yours and now it works fine.
by robby
I’ve been able to use negative offset values for the offset_float with hoverboard motors, pretty sure that’s not an issue. from the hoverboard guide:
Meaning values close to -1.5, -0.5, 0.5, or 1.5, etc are all good
