I have recently updated the firmware of the Odrive 3.6-56V board to 12-devel branch for CAN development, and I am aware of the change in the control interface mentioned in this CHANGELOG
With this new firmware, I was able to pass the FULL_STATE_CALIBRATION without any error.
I then ran following code to set the motor into velocity control
odrv0.axis0.requested_state=AXIS_STATE_CLOSED_LOOP_CONTROL
odrv0.axis0.controller.config.input_mode=CTRL_MODE_VELOCITY_CONTROL
odrv0.axis0.controller.input_vel = 20000
The motor did start turning, but only at an extremely slow speed. Increasing the input_vel and vel_limit didn’t make it faster.
I have been using this Odrive board with firmware version 11 for a while and there was no problem.
I was wondering if you can help me with this issue, and let me know if you need more information.
Here is the odrv0.axis0.controller results:
error = 0x0000 (int)
input_pos = 0.0 (float)
input_vel = 20000.0 (float)
input_current = 0.0 (float)
pos_setpoint = 0.0 (float)
vel_setpoint = 0.0 (float)
trajectory_done = True (bool)
vel_integrator_current = 0.0 (float)
anticogging_valid = False (bool)
config:
control_mode = 3 (int)
input_mode = 2 (int)
pos_gain = 20.0 (float)
vel_gain = 0.0005000000237487257 (float)
vel_integrator_gain = 0.0010000000474974513 (float)
vel_limit = 20000.0 (float)
current_ramp_rate = 1.0 (float)
homing_speed = 2000.0 (float)
inertia = 0.0 (float)
axis_to_mirror = 255 (int)
mirror_ratio = 1.0 (float)
load_encoder_axis = 0 (int)
anticogging: …
move_incremental(displacement: float, from_goal_point: bool)
