I am reading the source code and wondering which function calls the Encoder::update()?
Your question is a little vague. Are you wanting to know what function is used to poll the encoder position?
I guess a better question would be, what are you trying to accomplish?
Here is the call stack for the idle loop:
There would be a similar one when other states are running, they trace a similar path from a different state in run_state_machine_loop.
Get it. Thanks ~
By the way, how did you make this figure? Are you using the Eclipse IDE?
I’m using the cortex-debug extension in VSCode.
