Hi, I am new to odrive and I tried to follow the “getting started”-guide word by word. However,
I cannot get the Motor connected to M0 to stop vibrating. The same motor connected to M1 works fine. I switched the motors ( I have 2 D6374 150KV) and the encoders (CUI AMT102). It always seems to be the motor connected to M0. Switched motor-cables, encoder-cables and rearranged the cables to make sure nothing is overlapping.
The configuration for both controllers are identical.
In [20]: odrv0.axis1.controller
Out[20]:
error = 0x0000 (int)
input_pos = 0.0043659210205078125 (float)
input_vel = 0.0 (float)
input_torque = 0.0 (float)
pos_setpoint = 0.0043659210205078125 (float)
vel_setpoint = 0.0 (float)
torque_setpoint = 0.0 (float)
trajectory_done = True (bool)
vel_integrator_torque = 0.0 (float)
anticogging_valid = False (bool)
config:
control_mode = 3 (int)
input_mode = 1 (int)
pos_gain = 20.0 (float)
vel_gain = 4.999999873689376e-05 (float)
vel_integrator_gain = 0.0 (float)
vel_limit = 20000.0 (float)
homing_speed = 0.25 (float)
inertia = 0.0 (float)
axis_to_mirror = 255 (int)
mirror_ratio = 1.0 (float)
load_encoder_axis = 1 (int)
anticogging: ...
move_incremental(displacement: float, from_input_pos: bool)
In [19]: odrv0.axis0.controller
Out[19]:
input_pos = -0.017759323120117188 (float)
pos_setpoint = -0.017759323120117188 (float)
config:
load_encoder_axis = 0 (int)
anticogging: ...
Odrive Serial Number:
35722209414477
Firmware Version: 0.5.1
HW Version: 3.6
Variant: 24V
Am I missing something?
how much vibration is ok? I can feel it, when I touch it. I can also hear it slightly, but I don’t feel nor hear anything on M1.
