Hello, I’m new to the ODrive scene. I’m working on my school graduation project in which I need to control the velocity of an electric motor with an ODrive S1 and an Arduino Uno. Unfortunately, I haven’t been able to get my code running. Can somebody help me with this?
With kind regards from Austria!
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#define I2C_ADDRESS 0x3c
#include <ODriveUART.h> // ODrive
#include <SoftwareSerial.h> // ODrive
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd1(0x27, 16, 2);
LiquidCrystal_I2C lcd2(0x3F, 16, 2);
/* MASTER */
#define NODE_MAX_NUMBER 5
#define PAYLOAD_SIZE 2
int nodePayload[NODE_MAX_NUMBER][PAYLOAD_SIZE];
SSD1306AsciiWire oled;
const int button1 = 2;
const int button2 = 3;
const int button3 = 4;
const int outputPin = 7;
const int button4 = 5;
const int button5 = 6;
const int outputPin1 = 12;
bool output = false;
int frequency = 900;
int step = 20;
int maxmodes = 3;
int Modus = 1;
int Modus1 = 0;
int Modus2 = 0;
int Modus3 = 0;
// ODrive
ODriveUART odrive(Serial);
void setup() {
lcd1.init();
lcd2.init();
lcd1.backlight();
lcd2.backlight();
Wire.begin();
Wire.setClock(400000L);
oled.begin(&Adafruit128x64, I2C_ADDRESS);
Serial.begin(115200);
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
pinMode(outputPin, OUTPUT);
pinMode(outputPin1, OUTPUT);
outputoled();
outputlcd();
void loop() {
int button1state = digitalRead(button1);
int button2state = digitalRead(button2);
int button3state = digitalRead(button3);
int button4state = digitalRead(button4);
int button5state = digitalRead(button5);
if (button1state == HIGH) {
output = !output;
updatedisplays();
if (button2state == HIGH) {
frequency += step;
updatedisplays();
if (button3state == HIGH) {
frequency -= step;
updatedisplays();
if (button4state == HIGH) {
if (Modus + 1 > maxmodes) {
Modus = 1;
} else {
Modus += 1;
updatedisplays();
if (button5state == HIGH) {
if (Modus - 1 <= 0) {
Modus = maxmodes;
} else {
Modus -= 1;
updatedisplays();
if (output == 1) {
if (frequency < 1) { frequency = 1; }
Modus1 = ((1000 / (frequency / 60)) * 2) / 6;
Modus2 = (1000 / (frequency / 60)) * 0;
Modus3 = (1000 / (frequency / 60)) * 2;
switch (Modus) {
case 3:
digitalWrite(outputPin, HIGH);
delay(Modus3);
digitalWrite(outputPin, LOW);
delay(Modus3);
// Setze die Drehzahl des Motors über ODrive
setMotorSpeed(frequency / 2); // Drehzahl auf frequency/2 setzen
break;
case 2:
delay(Modus2);
delay(Modus2);
break;
case 1:
delay(Modus1);
delay(Modus1);
break;
default:
// Setze die Drehzahl des Motors über ODrive auf 0
setMotorSpeed(0);
break;
digitalWrite(outputPin1, HIGH);
} else {
digitalWrite(outputPin1, LOW);
setMotorSpeed(0);
int updatedisplays() {
outputoled();
outputlcd();
delay(100);
int outputlcd() {
lcd2.clear();
if (output) {
lcd2.setCursor(0, 0);
lcd2.print("Modus:");
switch (Modus) {
case 1:
lcd2.setCursor(0, 1);
lcd2.print("CR");
break;
case 2:
lcd2.print("ESP");
break;
case 3:
lcd2.print("BENZ");
break;
default:
lcd2.print("Modus nicht vorhanden");
} else {
lcd2.print("HTL1/Bosch ELHA");
lcd2.print("Druecken Sie Start");
int outputoled() {
oled.setLetterSpacing(2);
oled.clear();
if (output) {
oled.setFont(Cooper19);
oled.println("RPM");
oled.print(frequency);
oled.print(" U/MIN");
} else {
oled.println("HTL 1");
oled.println("BOSCH ELHA");
oled.setFont(TimesNewRoman16);
oled.println("Druecken Sie Start");
void setMotorSpeed(float targetRPM) {
// Konvertiere die Ziel-Drehzahl von U/min in Schritte pro Sekunde (counts/s)
float targetVelocity = targetRPM * ODRIVE_COUNTS_PER_REV / 60.0;
odrive.SetVelocity(0, targetVelocity);
