I’ve been working on getting the native protocol to work over UART using a teensy/Arduino.
After scouring the documentation and some Wireshark sniffing of the USB transactions between the python odrivetool and the board I finally got it to reply. But the responses make no sense.
I’m running FW 0.5.1RC and running odrivetool generate-code tells me that my json_crc is 0x9B40. UART Baud is 115200.
When I sniff the USB calling the serial_number endpoint, 4, I get the following (chosen since it outputs the same number every time):
Request: 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x40, 0x9B
Response: 0x91 0x80 0x48 0x50 0x7A 0x33 0x5E 0x20
which corresponds to the correct serial number of 20 5E 33 7A 50 48 (HEX) / 35588962668616 (dec)
I can correlate the above the protocol documentation and it makes sense.
The issue is now when I go to use it over UART. I set tup.config to native for the UART and flashed the firmware.
It is my understanding the the UART expects the stream version of the protocol.
I dug into /Firmware/fibre/python/fibre/protocol.py and tried to figure out the proper packet format for a Stream.
After hours of playing, I finally got replies from the ODrive when I sent the following request for the serial number:
byte request = {0xAA, 0x06, 0x00, 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x0A, 0x33};
I calculated the last 2 CRC16 bytes using the polynomial and initial value at the bottom of the documentation for {0x91, 0x00, 0x04, 0x80, 0x08, 0x00} to be 0x0A33
Here’s where I’m lost (although probably sending the wrong thing too).
When I send a “valid” request, the reply I get from the ODrive is always:
756E6B6E6F776E20636F6D6D616E64DA (HEX).
Out of curiosity, the following permutations of the request all have the same response as above (others give nothing):
byte request = {0xAA, 0x06, 0x00, 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x0A};
byte request = {0xAA, 0x08, 0x00, 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x0A};
byte request = {0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x0A, 0x33};
byte request = {0xAA, 0x06, 0x00, 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x33, 0x0A};
I looked through the raw binary output on both my serial terminal and on a oscilloscope to see if I can find the “10101010” representing AA without luck (assuming that maybe there was a shift in the data).
Any suggestions on where I’m going wrong?
Thanks in advance,
Matt
P.S. Here is my teensy code:
#include <Arduino.h>
void setup()
Serial.begin(115200);
Serial3.begin(115200);
elapsedMillis sendCommandTimer;
byte request[] = {0xAA, 0x06, 0x00, 0x91, 0x00, 0x04, 0x80, 0x08, 0x00, 0x0A, 0x33};
//byte request[] = {0xAA, 0x08, 0xFC, 0x00, 0x91, 0x80, 0x04, 0x00, 0x08, 0x9B, 0x40, 0xE6, 0x5E};
void loop()
if (sendCommandTimer > 20)
Serial.println();
Serial.println("new send");
sendCommandTimer = 0;
Serial3.write(request,11);
while (Serial3.available() > 0)
byte c = Serial3.read();
Serial.print(c,HEX);
