Hi All,
To test my hardware (2 motors driving belts / “tank”) I wanted to connect an RC receiver and remote control the setup. I am using a Spectrum AR400, and the receiver is tested with servos to be sending the appropriate pulses.
I have wired up the Odrive to the motors and encoders, and via USB I can control both axis by following the examples in the documentaiton.
But following the RC/PWM example, nd wiring a PWM output from the receiver to GPIO4, I get a software crash in the Odrive:
In [9]: odrv0.config.gpio4_pwm_mapping.min = -1500
In [10]: odrv0.config.gpio4_pwm_mapping.max = 1500
In [11]: odrv0.config.gpio4_pwm_mapping.endpoint = odrv0.axis0.controller._remote_attributes['pos_setpoint']
In [12]: odrv0.save_configuration
Out[12]: <fibre.remote_object.RemoteFunction at 0x26cf1fac748>
In [13]: odrv0.reboot
Out[13]: <fibre.remote_object.RemoteFunction at 0x26cf1fac828>
In [14]: odrv0.save_configuration()
In [15]: odrv0.reboot()
ChannelBrokenException Traceback (most recent call last)
~\Anaconda3\lib\site-packages\fibre\shell.py in <module>()
----> 1 odrv0.reboot()
~\Anaconda3\lib\site-packages\fibre\remote_object.py in __call__(self, *args)
160 for i in range(len(args)):
161 self._inputs[i].set_value(args[i])
--> 162 self._parent.__channel__.remote_endpoint_operation(self._trigger_id, None, True, 0)
163 if len(self._outputs) > 0:
164 return self._outputs[0].get_value()
~\Anaconda3\lib\site-packages\fibre\protocol.py in remote_endpoint_operation(self, endpoint_id, input, expect_ack, outpu
t_length)
313 return self._responses.pop(seq_no)
314 # TODO: record channel statistics
--> 315 raise ChannelBrokenException() # Too many resend attempts
316 finally:
317 self._expected_acks.pop(seq_no)
ChannelBrokenException:
In [16]:
