Hello, I bought a new ODrive 3.6 and using it with the Robo Wheels rw170. The encoders are running perfectly well (checked them using the odrive tool), the odrivetool library is working, and the electronic connections are there.
But every time I try the “Full Calibration” command, the wheel barely moves an inch. And from the docs page here: Getting Started — ODrive Documentation 0.0 documentation
It says I should hear a beep after 2 secs, and see the motor turn slowly.
Can anyone suggest what params to change to fix my problem and get the wheel to turn?
Thank you!
