Very new to dual shaft motors. But is the mount the only thing you can mount or can you mount the axles on something permanent so the main wheel can spin or does the main body and the axles spin while the mount does not?
The shaft is one solid shaft all the way through. It spins with the shell of the motor. The faceplate stays mounted to whatever you screw it to.
