I was working on my Project with an Odrive 3.6, sending some commands over the ASCII interface. Everything worked well until suddently Odrive disconnected. I cannot see it in the device manager anymore (I’m on Windows 10). When I switch the DFU switch, the board can be detected and I’m able to flash the latest (0.4.12) Firmware with the DfuSe app from ST without issue. However, when I switch back from DFU to RUN the board cannot be found again. Nothing in the device Manager and no new hardware notification…
Any Idea what it could be? Is the board broken? Strange thing is, I can connect to it in DFU mode and even flash the Firmware…
Thanks,
Maxime
