Hello!
I am new to Odrive, and so the mistake i am making might be very stupid, but I hope some of you can help me fix it.
I am running an Odrive v3.5, with v0.5.3 driver. Currently i am trying to control the motor through the odrivetool running on an RPi, with a USB connection to the Odrive board.
The two following commands issues the “beep” and then causes the motors to turn in one direction
odrv0.axis0.requested_state = CONTROL_MODE_POSITION_CONTROL
However, from the Odrive getting started documentation i can understand that the motors should turn both directions.
If i run the following commands, nothing happens, regardless of changing control mode.
odrv0.axis0.controller.input_pos = 2
odrv0.axis0.controller.input_vel = 2
The motors are powered by a 17V 5A Tabletop power supply, and when the motors start turning during calibration sequence, it only draws 1A, so i am confident, that it is not a power problem.
Below is the config of my motor and controller along with the output of dump_errors from odrivetool.
I have tried to post as much information as i thought was relevant, but being green in the field might mean that i have left something out, please let me know, and i will try and find it asap.
The config of my odrv0.axis0
In [19]: odrv0.axis0.controller.config
Out[19]:
anticogging:
anticogging_enabled: True (bool)
calib_anticogging: False (bool)
calib_pos_threshold: 1.0 (float)
calib_vel_threshold: 1.0 (float)
cogging_ratio: 1.0 (float)
index: 0 (uint32)
pre_calibrated: False (bool)
axis_to_mirror: 255 (uint8)
control_mode: 3 (uint8)
electrical_power_bandwidth: 20.0 (float)
enable_torque_mode_vel_limit: True (bool)
enable_vel_limit: True (bool)
homing_speed: 0.25 (float)
inertia: 0.0 (float)
input_mode: 1 (uint8)
load_encoder_axis: 0 (uint8)
mechanical_power_bandwidth: 20.0 (float)
mirror_ratio: 1.0 (float)
pos_gain: 20.0 (float)
spinout_electrical_power_threshold: 10.0 (float)
spinout_mechanical_power_threshold: -10.0 (float)
steps_per_circular_range: 1024 (int32)
torque_mirror_ratio: 0.0 (float)
torque_ramp_rate: 0.009999999776482582 (float)
vel_gain: 0.1666666716337204 (float)
vel_integrator_gain: 0.3333333432674408 (float)
vel_limit: 3.0 (float)
vel_limit_tolerance: 1.2000000476837158 (float)
vel_ramp_rate: 1.0 (float)
odrv0.motor.config
In [25]: odrv0.axis0.motor.config
Out[25]:
I_bus_hard_max: inf (float)
I_bus_hard_min: -inf (float)
R_wL_FF_enable: False (bool)
bEMF_FF_enable: False (bool)
calibration_current: 5.0 (float)
current_control_bandwidth: 1000.0 (float)
current_lim: 5.0 (float)
motor_type: 0 (uint8)
phase_inductance: 0.0007919398485682905 (float)
phase_resistance: 0.3521248400211334 (float)
pole_pairs: 7 (int32)
requested_current_range: 60.0 (float)
torque_constant: 0.03999999910593033 (float)
torque_lim: inf (float)
Errors dumped by Odrivetool
In [23]: dump_errors(odrv0)
system: no error
axis: no error
motor: no error
encoder: Error(s):
ENCODER_ERROR_CPR_POLEPAIRS_MISMATCH
axis1
axis: no error
motor: no error
