odrive has no error
I set all motor parametes, encoder and performed FULL Calibration command then, CLOSED Loop control command. AXIS1 is working great but Axis0 doesn’t hold it’s positon.
So Axis1 works when do positon command, Axis0 doesn’t…
It’s hard to tell but it look like one motor has a lot more friction on it than the other. Make sure both motors work before you mount them in the device, then mount them & tune the gains.
