We are connecting an ODrive Micro to a US Digital EM-2 5000 CPR incremental encoder and T-motor RI50 motor, and experiencing two problems:
The “Apply & Calibrate” GUI screen seems to have a bug where Calibrate (step 4) isn’t active after clicking “Save & Reboot” (step 3). If we click “Apply” again (step 2), then the “Run Calibration Sequence” button becomes active again, and we can calibrate.
Running calibration moves the motor, but it fails to detect the encoder. The motor moves around 180° to do the calibration, but the encoder calibration fails with “NO_RESPONSE”.
Problem #2 is the main issue.
Note: our index pulse is irregular (probably due to misalignment in the test rig), so we would like to calibrate the encoder without the index.
I’ve attached some photos of our setup and debugging. Troubleshooting we have done so far:
- We have tried different settings for the encoder: CPR 20000 and 5000, index disabled and enabled. All fail with the NO_RESPONSE status.
- We have updated to the latest firmware, and tried the same process via
odrivetoolas well as the GUI. Same failure. - We have measured the 5V and GND pins on the encoder side, and confirmed a voltage of 4.6V.
- We have scoped the A and B signals from the encoder, and confirmed that we see the quadrature signal when the motor is moving during calibration.
So questions:
- Can the ODrive Micro calibrate with an incremental encoder without an index signal?
- Is the pinout on the ODrive Micro datasheet page correct? We have triple-checked the wiring and definitely have the right pins connected per the datasheet (pins 3-7).
- Any other suggestions on what to try?
We would really like to use the ODrive Micro for this project, but this issue is a complete blocker for us right now.
Thanks,
Matt
ODrive Micro showing connections:
