I am trying to get Odrive Micro with AS5048A encoder. While trying to calibrate motor with plugged through SPI encoder I got an NO_RESPONSE error. First time I plugged encoder wrongly (bad wiring) so I change it, but error stays the same. Could I damage the SPI port of the Odrive? Everything else works fine alongside with onboard encoder reading. I try to understand how it works, because even after setting SPI encoder through gui or odrivetool, nCS pin is set to HIGH. I tried with pull-up resistor for nCS after reading about about possible initialization error of this encoder because of messages sent during boot up (docs/encoders.md: recommend a pull-up resistor on CS pin for AMS enco… · szeder/ODrive@66e4856 · GitHub), but it does not help. I will be very grateful for any help and hint to resolve this.
