Motor: https://hobbyking.com/en_us/turnigy-c580l-580kv-brushless-inrunner-motor-4000w.html
Encoder: https://www.digikey.com/product-detail/en/cui-inc/AMT102-V/102-1307-ND/827015
Brake Resistor:
https://www.mouser.com/ProductDetail/ARCOL-Ohmite/HS50-1R-F?qs=bvCpHSZmQjnH%2bJp5QsKn8A%3D%3D
Odrive: 3.5 24V
I’ve looked up the motor error “0x11” on the forums, but nothing has really seemed to better the situation. The motor used to partially run when “odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQUENCE” was entered, but it was very inconsistent. Meaning it would maybe turn once out of every 3 times it was entered. Also it only ever turned in one direction, and then stop. Not both directions as it should have.
Then it stopped turning all together after trying to fix that issue.
All I’m getting now is a very small twitch at the beginning and then it stops and outputs error 0x40 & motor error 0x11 from which I understand is ERROR_CONTROL_DEADLINE_MISSED and ERROR_PHASE_RESISTANCE_OUT_OF_RANGE.
Any ideas on how to go about this, it would be greatly appreciated.
Most of my configs & errors are below.
Thank you!
In [208]: odrv0.vbus_voltage
Out[208]: 12.132494926452637
In [209]: odrv0.axis0.motor.config.current_lim
Out[209]: 75.0
In [210]: odrv0.axis0.motor.config.requested_current_range
Out[210]: 90.0
In [211]: odrv0.axis0.controller.config.vel_limit
Out[211]: 40000.0
In [212]: odrv0.axis0.motor.config.calibration_current
Out[212]: 50.0
In [213]: odrv0.config.brake_resistance
Out[213]: 1.0
In [214]: odrv0.axis0.motor.config.pole_pairs
Out[214]: 12
In [215]: odrv0.axis0.motor.config.motor_type
Out[215]: 0
In [216]: odrv0.axis0.encoder.config.cpr
Out[216]: 8192
In [217]: odrv0.axis0.requested_state = AXIS_STATE_FULL_CALIBRATION_SEQENCE
In [218]: hex(odrv0.axis0.error)
Out[218]: ‘0x40’
In [219]: hex(odrv0.axis0.motor.error)
Out[219]: ‘0x11’
In [222]: hex(odrv0.axis0.encoder.error)
Out[222]: ‘0x0’
In [223]: odrv0.axis0.motor.config.phase_inductance
Out[223]: 0.0
In [224]: odrv0.axis0.motor.config.phase_resistance
Out[224]: 0.04754049703478813
In [225]: odrv0.axis0.motor.current_control.p_gain
Out[225]: 0.0
In [226]: odrv0.axis0.motor.current_control.i_gain
Out[226]: nan
In [228]: odrv0.axis0.motor.config.resistance_calib_max_voltage
Out[228]: 2.0
In [230]: odrv0.axis0.config
Out[230]:
counts_per_step = 2.0 (float)
ramp_up_time = 0.4000000059604645 (float)
ramp_up_distance = 12.566370964050293 (float)
spin_up_current = 10.0 (float)
spin_up_acceleration = 400.0 (float)
spin_up_target_vel = 400.0 (float)
In [231]: odrv0.axis0.motor.config
Out[231]:
pre_calibrated = False (bool)
pole_pairs = 12 (int)
calibration_current = 50.0 (float)
phase_inductance = 0.0 (float)
phase_resistance = 0.04754049703478813 (float)
direction = 1 (int)
motor_type = 0 (int)
current_lim = 75.0 (float)
requested_current_range = 90.0 (float)
In [232]: odrv0.axis0.encoder.config
Out[232]:
mode = 0 (int)
use_index = True (bool)
cpr = 8192 (int)
offset = 0 (int)
offset_float = 0.0 (float)
