Odrive not Powering ON with 56 V battery
I have a 56 V v3.6 odrive. It was working perfectly fine. My battery once supplied 56.6 V and since then it has stopped powering ON. When I give the battery supply, the M0 side and right side of the Odrive heats up.
Request support!
Hi sum2305, unfortunately it sounds like you’ve burned a chip. You’ll have to do some probing with a multimeter to check the 56V rail, the 5V rail, and the 3.3V rails. Also you’ll want to check the resistance between the 56V and GND.
