Hi. I have made myself an ODrive v3.4, so now it doesn’t have a firmware on it. Will it work if I flash directly the master on my ODrive v3.4 right now? Or do I have to do something more?
Thank you
Thank you
See the Getting Started Guide or this DFU guide https://docs.odriverobotics.com/odrivetool.html#device-firmware-update
I’ve v3.4 since 3 years ago and I wanted to upgrade the firmware (it’s using still old object like odrv0.motor1 instead of axis, etc). I don’t find in the github repository the 0.5.1 firmware compatible with v3.4, but only with v3.5 and v3.6 hw versions.
Also, there are many warnings not to use firmware for a different hw version… but… where can I get 0.5.1 firmware upgrade "compatible with v3.4 hardware? I know that I will have to use STLink and not dfu…
Thanks
@Wetmelon I’m facing the same issue as @anunez. Is there a way to work with odrivetool 0.5.4 and Odrive v3.4?
Sure, you can just flash 0.5.4… might have to build from source, though. Are you 48V or 24V?
Ok, hop onto the discord channel and I’ll send you a build.
Can I still have the build 0.5.4 for v3.4 hw? thanks
