Hello
After updating the firmware on my ODrive v3; I faced an issue where the motor no longer responds to commands. I have followed all the necessary steps in the update process; including verifying the version, resetting configurations & restarting the system. However; despite multiple attempts to recalibrate the motor, it refuses to move or produce any output when commanded. ![]()
Upon investigating; I verified that the motor & ODrive are correctly wired & the power supply is providing the proper voltage. The ODriveās LED status indicator is showing a steady light, which suggests the system is powered on correctly, but Iām not seeing any activity when sending position or velocity commands through the control interface. I have tried reloading the firmware and running the āodrivetoolā to troubleshoot, but the motor still wonāt respond.
I have checked Getting Started ā ODrive Documentation 0.6.10 documentation Java documentation guide but still need advice .
I would appreciate any advice on how to proceed with diagnosing this issue. Could it be related to the firmware version compatibility / is there a specific reset or configuration step I may have missed? ![]()
Also; are there any logs or diagnostics I can run to pinpoint the cause of this failure?
Thanks in advance for your help! ![]()
