Hi, I’m trying to configure an Odrive Pro to control a bldc motor with an hall effect encoder but i have some problems. I already did it on the normal Odrive but it seems that some config commands are not the same for the Odrive Pro.
I tried to configure the Odrive Pro with the Odrive Pro documentation but in result, my encoder and controller are not found.
I think, I made some mistakes on the encoder config. I don’t really understand what should I chose for :
odrv0.axis0.config.load_encoder = EncoderID.HALL_ENCODER0
odrv0.axis0.config.commutation_encoder = EncoderID.HALL_ENCODER0
I replaced encoderID.HALL_ENCODER0 by ENCODER_MODE_HALL but I’m not sure of it.
Pro is very different. Please follow the Beta docs word for word.
You’re supposed to just copy & paste these values.
Thanks for your reply. I tried to copy past the values in the Beta docs but I received these errors :
I suspect that’s because it wants “EncoderID” and you’re giving it “EncoderId” with a lowercase “d”.
I receive the same error when I use EncoderID :
In that case I’m sorry but I don’t know what to recommend. I’m here in a similar situation to you: the product I bought doesn’t work, I have no intuition as to why not, and there’s absolute radio silence when I come here to ask about it.
Maybe someone else who bought an ODrive Pro might chime in and help you. Otherwise I think we’re on our own.
Are you using the ODrive Pro odrivetool? pip install --upgrade odrive --pre
Thank you, it’s why it didn’t work. Errors desappeared and i can use the command lines.
