Does anyone know what this error means?
openocd -f interface/stlink.cfg -f target/stm32f4x.cfg
GNU MCU Eclipse OpenOCD, 64-bitOpen On-Chip Debugger 0.10.0+dev-00593-g23ad80df4 (2019-04-22-20:25)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 2000 kHz
adapter_nsrst_delay: 100
none separate
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 2000 kHz
Error: open failed
make: *** [Makefile:17: flash] Error 1
What I have tried:
1)
OPENOCD := openocd -f interface/stlink.cfg \
$(if $(value PROGRAMMER),-c 'hla_serial $(PROGRAMMER)',) \
OPENOCD := openocd -f interface/stlink-v2.cfg \
OPENOCD := openocd -f interface/stlink-v2-1.cfg \
- reinstalling OPENOCD
- running
make flashwhile the odrive is powered and plugged in - reading through the link that is provided in the error here
I can’t seem to figure out what is going on.
Is running make flash required in order to flash a new firmware to the board? Or can I just compile the firmware and then flash the resulting .hex file?
