Hi all
is there a startup command in the Odrive that makes an actuator moving automatically to a certain (start-) position between the retracted and extracted actuator-position; and then makes this position to zero?
As I dont have endstops and the homing function anymore I have to find a way to make it like described in order to be able to use a different interface software (mover interface from the Xsimulator board)
I’m using the endstop firmware, van you tell me what’s not working with yours, I had a lot off problems too and fixed them all so maybe I know what’s wrong.
Hi Stijn,
Super, thanks!
I will give the endstop fimware a second chance this weekend because I think some of the problems I had came from my too weak PSU.
Do you use the Zennix firmware?
Because I suspected my power supply to be a problem with the endstop firmware, I bought 3 car batteries, which I can connect in series to get 36V.
With this power supply I made many attempts the last 2 days…and I am almost going crazy.
Odrive main-branch-firmware:
Test with 36V - power supply: runs smoothly without problems, but has no endstops and therefore I cant use it with the interface software.
=> currently no solution
Old Endstop firmware from Sept. 2018:
Tests with 12V from car battery: Starts clean, makes a clean homing but GPIO pin5 (the upper endstop for me) does not work.
Super strange!: Test with 24V from car battery - no changes on the simulator, wiring or parameters - only change from 12V to 24V: Result: The endstops are not recognized anymore. No Homing .
=> No solution
Back to the current RazorsEdge:
Test with 12V and 24V: Start and homing without problems!..BUT: at one of the two actuators the endstops are no longer working. The signals are not recognized, although I measured the input signals directly at the Odrive input.
=> No solution
So…what now???
I think I have to wait until the Endstops are integrated in the main branch firmware and tested by Wetmelon…
Maybe you could send me your firmware as a *.elf file? and the matching configuration file ? For a last tryal…
Try it with the command to be sure, also try with an external pullup or pulldown resistor. I had problems with this too, it just would not home and then I found out that the switches we’re just not being read.
