I’m currently running a ducted fan from odrive and seem to be running into issues with the top speed I am able to achieve.
motor is a dr mad thrust 3900KV
I can change the odrv0.axis0.controller.set_vel_setpoint between 0 and 4000 and get different speeds but any value above that has no change on the motors speed.
odrv0.axis0.motor.config.pole_pairs = 3
odrv0.axis0.config.spin_up_current = 10.0
odrv0.axis0.config.spin_up_acceleration = 1000.0
odrv0.axis0.config.spin_up_target_vel = 1000.0
odrv0.axis0.controller.config.control_mode = 2
odrv0.axis0.controller.config.vel_gain = 0.01
odrv0.axis0.controller.config.vel_integrator_gain = 0.05
odrv0.axis0.controller.vel_setpoint = 400
odrv0.axis0.sensorless_estimator.config.pm_flux_linkage = 0.0004922
odrv0.save_configuration()
#reboot
odrv0.axis0.requested_state = AXIS_STATE_SENSORLESS_CONTROL
am I missing any part of the set up for sensorless or have any part drastically wrong.
I tried to set up a new motor and drive with these parameters to match the first one and it starts the pinup then loses a step and starts to slowly turn and vibrate. even though the motor is the same as the previous one does it need seperate tuning rather than reusing the previous values?
thanks
